My first experiment is working with Neon lamp (dot type). This lamp has same characteristic with nixie tube. I used opto isolation chip TLP627 because it can isolate up to 300VDC.
DC step-up module is used to convert from 12VDC to 150VDC to light on the lamp.
Here is video about my first experiment:
Main point of this experiment is to check if DC step-up module and isolation chip TLP627 can work together or not. Also, understand working principle of Neon lamp (nixie tube)
After successful, i will do with Nixie tube
Please wait until the project complete with nixie clock!
Marcin Saj
Laboratorio Gluón
Dillon Gutowski
i've check out voltage between two electrode of nixie tube, it is 130VDC! And it is still working with optocoupler chip.
