2/8/2020 - The Project Finale
A project log for Scoreboard
A one digit Scoreboard that keeps track of your score
george-ebeidGeorge Ebeid 02/09/2020 at 00:040 Comments
I have stayed up until 1:30am which is last morning to figure out how to get the scoreboard to transition from 9 to 0 and vise versa. at first I used a bunch of logic gates and a flip flop at first but it is all in vain. Then I realized that I was overthinking this process. I need only 4 logic gates and three output with the first output at the and gate and the fifth output at the load pin of the sn74ls169bn. I did trial and error and intuition to get the logic output right. I test it out and it worked. This is the last part of which I want to implement into the circuit. All I need to do is to draw the schematic and the PCB board.
Here is the video of the circuit:
Here are images of the circuit:
