Been a minute and I've currently found some motivation to work on animations and make the code run faster plus also mapping things finally.
Found out the ESP32 only has a 64 byte hardware buffer for I2C and that I need to use endTransmission after 63 bytes, stole some adafruit code for I2C oled displays and put it in the library I'm currently using for the IS31FL3733.
Here's a snippet of the I2C write section.
Wire.beginTransmission(i2c_addr);
Wire.write((byte) reg_addr);
uint16_t rounds = 1;
uint16_t bytesOut = 1;
uint8_t *ptr = buffer;
#if defined(ESP32)
while (count--) {
if (bytesOut >= 64) {
Wire.endTransmission();
Wire.write((byte) reg_addr + 63*rounds);
bytesOut = 1;
rounds++;
Wire.write((byte)(*ptr++));
bytesOut++;
return 1;
#else
for (uint8_t i = 0; i < count; i++) {
Wire.write((byte)(buffer[i]));
return 1;
#endif
davedarko
