Stray Capacitance on the GPIO pins?
A project log for Integrated Circuit Tester & Exploratory Tool
Interactive tester and exploratory tool for logic chips
john-lonerganJohn Lonergan 01/31/2020 at 02:512 Comments
I wrote up some docs on what I've been seeing as strange results for stray capacitance on the GPIO pins.  See "Stray Capacitance" in the GitHub README for full details.
I can't understand how the signal takes so long to decay - am I wrong about this being just RC from the pcb trace & zif socket? The RC would be tiny but the decay takes 25 secs.
Ken Yap wrote 01/31/2020 at 03:03 point
One of the hits I got is a Cornell University course that says: "The input impedance, in either state, of CMOS gates is typically 10^12 Ω. The input capacitance is 5 pF."
Do those values give you numbers closer to what you observed?
John Lonergan wrote 01/31/2020 at 08:15 point
Hmm? ...Well if it was 10^12 ohm rather than 100mohm and I assume 20pf in the input plus the trace plus the zif then I think it comes to 20secs which is definitely in the right ballpark. That's really helpful Ken if this is right. Thanks i'm not bonkers after all.
