Interactive Exploratory GUI
A project log for Integrated Circuit Tester & Exploratory Tool
Interactive tester and exploratory tool for logic chips
john-lonerganJohn Lonergan 02/26/2020 at 02:580 Comments
Got around to creating a GUI for the exploratory function.
Alows one to pick the config for the test pins and then displays the result of the test, highlighing the outcome of any pin value expectations in green and red.
Each pin is equiped with a cfg drop down...
