Received OSHpark boards and parts to assemble and test this design. Also, 3d printed a wall-plate to use for now. This design is using a touch sensor behind the wall-plate to activate the relay. Initially was concerned about the touch sensitivity however, touch sensitivity is actually great, even through the plastic plate.
