Odroid_C2_case_4.4mm.svgFor 4.4 mm plywood (gabun)svg+xml - 16.32 kB - 02/01/2020 at 21:05 |
Odroid_C2_case_4.4mm.dxfFor 4.4 mm plywood (gabun)AutoCAD DXF - 92.99 kB - 02/01/2020 at 21:05 |
svg+xml - 49.96 kB - 02/01/2020 at 21:04 |
AutoCAD DXF - 317.67 kB - 02/01/2020 at 21:04 |
svg+xml - 52.51 kB - 02/01/2020 at 21:04 |
AutoCAD DXF - 341.39 kB - 02/01/2020 at 21:04 |
