wireless temp/hum sensor and connected objects
Hey! I have often thought about such a PCB. However, the range of the NRF24L01 in buildings somewhat discourages me. A SUB 1GHz system may be better suited for low data rate applications. Have you already been able to test the system and its range in the building?
It says that can arrive t 1km and more
and it have RSSI so u can control the signal quality
Looks great. What temperature sensor are you using?
I had a similar project, but never finished it.
PS some observations on the PCB. Running the ATMega328 at 16Mhz on only 3V is out of spec. That's why, for example, the 3.3V Arduino Pro Mini runs at 8Mhz. Also, the crystal is a bit far away from the ATMega.
I use the Si7021-A20 as a temperature / humidity sensor.
first time i developed the project using arduino nano ( i remove the regulator, led and some component) and maked the prototype. no i dont know why i installed 16 MHZ. thank you for this information i look for it
https://mysensors.ru/build/
https://t.me/mysensors_rus
Всё уже есть готовое! + открытые исходники.
Everything is already ready! + open source.
