Hardware discovery
A project log for USB/IP EZ
Create a usbipd server and nice gui client interface
dice-wasserDice Wasser 02/03/2020 at 08:560 Comments
Started looking into my dream hardware for this project,
it would probably be an AllWinner A13 based sbc with an embedded rtl8192cu on one of the usb bus and just a host connector on the other.  The reason I went with the RTL8192CU so far is because not many people like the allwinner network stack on the orange pi zero, also I like the low profile quad flat pack because I can solder it myself.
I was looking into STM32F7 and it only has 1 USB HS bus (and 1 FS bus) wile the A13 has 2 HS buses.
Also I wanted a USB based wifi stack because SDIO bus based stacks does not reach wifi speeds.
The other option being rocketchip with usb 3 as a future iteration
