IMG_7.jpgBrake coil and steel bearing housingJPEG Image - 1.13 MB - 02/04/2020 at 12:01 |
IMG_6.jpgThe main shaft and bearing preload lock nutJPEG Image - 912.09 kB - 02/04/2020 at 12:01 |
IMG_26.jpgBrake subassemblyJPEG Image - 1.31 MB - 02/04/2020 at 12:01 |
IMG_14.jpgMachining the brake disk (version 2.0)JPEG Image - 1.77 MB - 02/04/2020 at 12:01 |
IMG_13.jpgBearings preloadedJPEG Image - 1.34 MB - 02/04/2020 at 12:01 |
IMG_24.jpgClosed-loop stepper motor installedJPEG Image - 1.08 MB - 02/04/2020 at 12:01 |
IMG_12.jpgPreloading of the bearings with a custom made socketJPEG Image - 1.10 MB - 02/04/2020 at 12:01 |
IMG_21.jpgAssembly of the face plateJPEG Image - 1.04 MB - 02/04/2020 at 12:01 |
IMG_23.jpgClosed-loop stepper motor installedJPEG Image - 1.22 MB - 02/04/2020 at 12:01 |
IMG_15.jpgBrake disk inside the brake housingJPEG Image - 1.74 MB - 02/04/2020 at 12:01 |
IMG_20.jpgAssembly of the harmonic driveJPEG Image - 1.18 MB - 02/04/2020 at 12:01 |
IMG_1.jpgThe harmonic driveJPEG Image - 1.40 MB - 02/04/2020 at 12:01 |
IMG_16.jpgAssembly of the brake subassemblyJPEG Image - 1.22 MB - 02/04/2020 at 12:01 |
IMG_8.jpgBrake coil and steel bearing housingJPEG Image - 1.23 MB - 02/04/2020 at 12:01 |
IMG_22.jpgAssembly of the harmonic driveJPEG Image - 1.30 MB - 02/04/2020 at 12:01 |
IMG_2.jpgWinding the brake coilJPEG Image - 1.32 MB - 02/04/2020 at 12:01 |
IMG_18.jpgStepper motor housing (a 3D printed part in ABS with a fibreglass reinforced outer shell)JPEG Image - 1.15 MB - 02/04/2020 at 12:01 |
IMG_3.jpgMachining the steel bearing housingJPEG Image - 1.50 MB - 02/04/2020 at 12:01 |
IMG_10.jpgBeginning of assemblyJPEG Image - 1.03 MB - 02/04/2020 at 12:01 |
IMG_11.jpgBeginning of assemblyJPEG Image - 1.15 MB - 02/04/2020 at 12:01 |
IMG_5.jpgTurning the main shaftJPEG Image - 1.49 MB - 02/04/2020 at 12:01 |
IMG_4.jpgMachining the steel bearing housingJPEG Image - 1.35 MB - 02/04/2020 at 12:01 |
