Testing of the new flight controller
A project log for The Ball-Drone Project
Single rotor, "human-safe", selfmade ball-drone with air vanes for position control
benjamin-prescherBenjamin Prescher 10/17/2020 at 10:000 Comments
Once developed - it has to be tested. To keep things simple, a first test of the new flight controller took place on a standard 220mm 4X copter.
The first tests (and flights) went well ... This was the base to start with the further design and construction of the ball drone.
