Power source
A project log for Ultra low power LED
<1.5µA current consumption when continuously on, optional flashing mode
Christoph TackChristoph Tack 05/16/2020 at 18:310 Comments
Coin cell CR2032
These really DO NOT like current spikes.  So a lot of buffer capacitance will be needed to buffer the LED current spike.  Data from Energizer:
Battery life calculations show that the project could run about 1 year when ON-current is 5mA and OFF-current is limited to 1µA.
3V CR123A Lithium cells
store up to 1700mAh.  These will last a lot longer.
LIR2450
If a rechargeable solution is desired, then the 3.7V/120mAh LIR2450 can be used.  This cell tolerates current spikes much better.
