Turn, turn, turn
A project log for Breadboarded 3-Axis Sine-Cosine Controller
Build this controller to engrave the PCB for your permanent controller
darrin-bDarrin B 02/10/2020 at 00:590 Comments
One day, I just wanted to make a stepper motor rotate. A few TTL chips and a bunch of transistors later, it did.
A few days later, Hack-A-Day published an article about sine-cosine drivers. I had to try it.
What's the shortest path to sine-cosine? A quadrature oscillator made from a high-power dual op-amp. One chip, three resistors and three capacitors. No code, no drivers, no mail-order parts. Best of all, the chip was scavenged from a junked VCR.
I was stunned at how smoothly the motor turned. This project begins...
