​Polarity Problem​?
A project log for Breadboarded 3-Axis Sine-Cosine Controller
Build this controller to engrave the PCB for your permanent controller
darrin-bDarrin B 06/22/2020 at 21:550 Comments
In the log entry titled "Does it have to be pretty?", I mention the Polarity0/1 signals. The present ring modulator based system does not provide them. They are not used by the parallel interface, but would likely be handy to have available for other interfacing schemes.
I may restore the signals, I'm just not feeling motivated enough to make changes the breadboard right now.
