Characterizing a NAND2 gate
A project log for LCPU - A CPU in LED-Transistor-Logic (LTL)
This projects tracks my efforts to develop discrete LED-Transistor logic building blocks and designing a CPU from them.
timTim 02/15/2020 at 16:030 Comments
I designed a neat breadboardable LTL-NAND2 gate to test the design in hardware. You can find the PCB layout and a photo of the finished product above. I use a BAW56 dual-diode in a SOT23 package for the input diode. This form factor is much easier to handle than single diode SMD packages and there is no cost disadvantage. You can see the LED in the center of the PCB. I made a few variation with different LEDs: green (high Vf) and red (lower Vf) and different collector resistors.
Transfer characteristics were measured by using the DAC and ADC of an ATtiny416. You can see that different LEDs can be used to adjust the threshold levels of the NAND2 gate. Red with a low forward voltage leads to a L->H threshold around 1.65 V while green as it 2.24/2.33V depending on collector resistor.
To build up more complex circuits it is also important to study the effect of output loading. The figure above shows the NAND2 gate with floating output and with another NAND2 gate connected to it. The threshold is slightly shifted for the loaded output, but not to a level of concern.
The scope picture above shows the transient switching behavior of a loaded NAND2 output with green LED and 8.2k collector resistor. One can see that there are actually two elements to the rising edge. Initially, the voltage rises quickly and is then followed be a slower slope. During the initial part, the 3.4k base resistor of the connected gate helps pulling up the output. However, after the threshold voltage is reached, the current from the base transistor flows into the base of the transistor and the output is only pulled up by the 8.2k collector resistor.
The behavior of the NAND2 gate with 1.8k collector resistor, as shown above, is more consistent and shows a fast rising edge up to Vhigh. I therefore decided to focus on using 1.8k as a collector resistor.
