Hardware Required
Buy all Components for LED Chase Circuit from Utsource.net
LED Chaser Circuit
led chaser circuit
Useful Steps
Step 1 Solder All LED’s
LED Chaser Solder LED's
Step 2 Solder Base of both IC’s
LED Chaser Solder IC Bases
Step 3 Solder All Resistors
LED Chaser Solder Resistors
Step 4 Solder Both Capacitors
LED Chaser Solder Capacitors
Step 5 Solder Variable Resistor
LED Chaser Solder Variable Resistor
Step 6 Solder Power Connector
LED Chaser Solder power connector
Step 7 Let’s Power up the Circuit
LED Chaser Power up Circuit
