Acoustic levitation
Acoustic levitation uses sound traveling through a fluid -- usually a gas -- to balance the force of gravity.
Acoustic levitation is an interesting phenomenon: it takes advantage of the fact that sound waves carry mechanical energy in order to exert force on an object. In this case, that force is directed against gravity to make the object levitate. Unlike mag.netic levitation, acoustic levitation can be used on a wide range of materials (even insects), though it is a weaker force.
ino - 7.47 kB - 02/19/2020 at 02:09
Download
Standard Tesselated Geometry - 862.78 kB - 02/19/2020 at 02:08
Download
  • 1 × 3D-printed TinyLev
  • 1 × Arduino Nano with mini USB cable
  • 1 × Some Exposed wire
  • 72 × 10mm 40kHz transducers
  • 1 × L298N Dual Motor Drive Board
View all 10 components
