Motor control is the core of automation & robotics. Without locomotion or any movement, a robot is dull and lifeless. The H-bridge Motor Controller is a true concept for DC motor control. It gives you rotary control of the motor: move motors forward, backward and with varying speeds. In this project, we are going to design an H-Bridge Motor Controller/Driver Circuit for a small 9V DC motor.
For cheap Electronics Components Please Visit : UTSource
Hardware Required
Steps
pcbway h bridge                                            PCB Prototype
Follow All Steps Carefully from the Video Tutorial Above (Recommended)
Solder All Transistors
Solder All Resistors
Solder Ceramic Capacitor
Solder Push Buttons
Solder Power Connector
Solder DC Motor Input Wires
Let’s Power up the Circuit
Working Explanation
