Tambourine Clamp
A clamp for mounting a tambourine to a drum kit
I wanted a clamp for my tambourine, so I could mount it on a drum kit. The handle unscrews and allows for mounting using M4 bolts.
Standard Tesselated Geometry - 81.82 kB - 02/23/2020 at 14:23
Download
  • 1 × 3D Printed Clamp Body See "Files"
  • 1 × M8x18mm Cross Dowel Barrel Nut Commonly used in IKEA furniture. M8 crosshole, 12mm diameter, 18 mm long
  • 1 × M8x40 Bolt with Crossgrip Knob You can make your own! https://www.thingiverse.com/thing:1562501
  • 4 × M4x16 Bolt Panhead or sockethead
  • 4 × M4 Spring Washer
View all 6 components
  • It is strong enough
    Koen van Vliet03/01/2020 at 14:23 0 comments
    So far this tambourine clamp has survived 3 different drummers this weekend. I'd say that is a success!
  • Prettifying and test fitting
    Koen van Vliet02/24/2020 at 16:35 0 comments
    I printed the clamp out of black PETG. This looks a lot nicer than my initial blue PLA prototype. It should also be a fair bit stronger. I placed a black norprene tube around the rim of the tambourine to dampen the impact of the drumsticks a bit.
    The norprene tubing is 10mm outer diameter, 1.7 mm wall thickness.
View all 2 project logs
  • 1
    Remove the handle
    Remove the four screws that hold the handle in place.
  • 2
    Optional: Drill new holes
    If your tambourine has different hole positions you can either modify the STL or the tambourine by drilling new holes.
  • 3
    Print the Clamp Body
    Print the Clamp Body (See "Files" for STL)
    TIP: Print with the square hole down for maximum strength.
View all 6 instructions
Dan Maloney wrote 02/24/2020 at 17:59 point
Looks like it was meant to be there from the start. Nice job. I was going to question whether it would hold up to the hits, but I've printed jigs and tools that took quite a beating, so this should do fine.
Koen van Vliet wrote 02/24/2020 at 18:21 point
Thanks! This weekend it will be tested by me and another drummer. We'll see who manages to break it.
Edit: so far nobody managed to break it.
