Working on I2C
A project log for 2nd Use BMS
A high energy capacity Battery Management System for re-purposing used cell modules from EVs and other sources
nathaniel-verleeNathaniel VerLee • 08/27/2020 at 15:27•0 Comments
I’ve been able to successfully read back cell voltages from the BQ76930 IC and have begun organizing that code into a more concise I2C driver. Once i have finished that I will begin work in deciding what queries to typically capture from the chip and what sort of a less frequency check in procedure to make sure all setting in the chip are correct will be.
