Front.jpgFront view of the display, time is 9:05.JPEG Image - 2.28 MB - 03/03/2020 at 04:11 |
Exploded.jpgExploded view showing the two housing pieces and the circuit elements.JPEG Image - 1.04 MB - 03/03/2020 at 04:30 |
Inside.jpgView of the interiorJPEG Image - 2.03 MB - 03/03/2020 at 04:11 |
Main board.jpgView of the main board and the real-time clockJPEG Image - 2.43 MB - 03/03/2020 at 04:11 |
TFT.jpgView of TFT, with case openJPEG Image - 2.08 MB - 03/03/2020 at 04:11 |
Front.stl3D file of the Front of the Housing. I printed with the front of the housing standing upright on the printbed (as it will stand when finished). I used support.Standard Tesselated Geometry - 171.18 kB - 03/03/2020 at 04:20 |
Back.stl3D file of the Back of the housing. I printed with the back face of the back housing lying down on the print bed. I did not use any support.Standard Tesselated Geometry - 173.52 kB - 03/03/2020 at 04:20 |
Clock of Love v32.f3zFusion 360 file of the front and back housingf3z - 2.35 MB - 03/03/2020 at 04:00 |
Mom_TFT_clock06.inoArduino project, also include images.h into your project. Updated 3/4/2020 to include options for daylight savings time. Spring forward or Fall back!ino - 18.33 kB - 03/04/2020 at 17:19 |
images.hArduino project that includes the hour images. Used with Mom_TFT...h - 21.33 kB - 03/03/2020 at 03:41 |
ds3231_setTime.inoRun this file first to set the real-time clock. This program has a few variables so you can offset the hour to correct UTC time. Also, you can includes a few seconds adjustment to account for the compiling and uploading time. Load this to set the UTC time, then upload the Mom_TFT final program.- 2.89 kB - 03/04/2020 at 17:23 |
