Raspberry Pi NextCloud Server
Use a raspberry pi with NextCloud to store and synchronize datas
I've used my raspberry pi 3b+ to make a standalone nextcloud server.
I needed a cheap backup server, and since I had a raspberry 3B in one of my drawers, I chose to use it instead of buying a backup solution.
The main advantage of using a Raspberry is that it consumes little energy and is fully configurable. The solution therefore remains very flexible and scalable.
The main idea is to use NextCloud to duplicate my work data, which is cheaper than using a NAS with a RAID 5 or raid 1. Here a small 2.5 HDD do the job.
In addition, Nextcloud has interesting features in the context of access for customers, for example. You just have to declare the server in the DMZ of your router to provide access from the internet with a dyndns, for example.
Data takes a long time to copy. It took me several days to synchronize my TB of data.
I hope you find this useful, and I wish you good make =)
Raspebrry 3B V2 v15.f3z
Fusion 360 file
f3z - 10.55 MB - 03/03/2020 at 22:36
Download
Standard Tesselated Geometry - 2.20 MB - 03/03/2020 at 22:18
Download
Standard Tesselated Geometry - 305.45 kB - 03/03/2020 at 22:18
Download
  • 1 × Raspberry Pi 3B + or RPi 4 the case has been made for RPi3 B
  • 1 × Sata to USB Adapter cable
  • 4 × M3 screw
  • 1 × 30 mm fan with M3 screw
  • 1 × Hard Drive 2.5" mine is 2 Tb
View all 7 components
  • 1
    Print
    print the top cover then the bottom.
    If you have a RPi4 you need to modify the case.
  • 2
    install Raspbian on the SD card
    just follow this step :
    https://www.raspberrypi.org/documentation/installation/installing-images/
    then update the system :
    sudo apt-get update
    sudo apt-get upgrade
    in the console start raspi-config and enable SSH in the interfacing options :
    remove the X server at statup and enable automatic login
    then :
    configure the WLAN0 with a static IP adress :
    mine is 192.168.0.3/24
    DNS : 8.8.8.8 and 1.1.1.1
    its better to use the wlan cause the ethernet is shared with the USB bus. you will loose some bandwith.
  • 3
    Connect the HDD and configure the OS
    Connect the HDD, then install gparted in the console :
    sudo apt install gparted
    Start gparted and delete all data on the drive (make a backup first). Format it to ext4. you can use ntfs but it will be a little slow
    edit /etc/fstab
    sudo nano /etc/fstab
    add the line : /dev/sda1 /media/hdd ext4 defaults,noatime 0 1
    If you dont know what drive you are using, juste use lsblk in the console.
    sudo reboot
View all 7 instructions
