Testing the regression
A project log for Soldering lightsaber
The fastest soldering ever
marius-taciucMarius Taciuc • 03/12/2020 at 06:24•0 Comments
I finished reading the learning procedure and I was able to take the first samples for my linear regression. I then manually created quick graph, because I was so curious if this data could really be estimated as a line and how accurate my automatic predictions could be.
The results are pretty promising.
