Breadboarding with the Sharp Memory LCD
A project log for Rubble Watch
A minimal DIY Pebble-inspired smartwatch... eventually
dandelanydan.delany 03/04/2020 at 08:121 Comment
One of the first decisions I made on this project was to use a Sharp Memory LCD display, the same display technology used in the Pebble smartwatches. These displays fill a great niche IMO - they're sunlight-readable like e-ink, but they have a much faster refresh rate (can do smooth animations) and still use very low power.
The easiest way to get started playing with this tech is to buy a breakout board from Adafruit ($25) and hook it up to an MCU with enough RAM to keep a framebuffer in it. I got started breadboarding it with a Trinket M0. The Trinket is pretty minimal, but it's enough to start tinkering with the hardware. I programmed it using Arduino and the Adafruit Sharp Memory Display code library.
I also wanted to experiment with an external low-power RTC for timekeeping, so I added a DS3231 breakout. The DS3231 communicates over I2C and, once again, comes with an easy-to-use Arduino library from Adafruit - see the tutorial for details.
So here's my first bit of hardware - a minimal Arduino clock on a breadboard!
robomaniac wrote 04/21/2020 at 12:05 point
Hey Dan,
In the Adafruit_GFX lib, what font did you use? The "FreeSans9pt7b.h" ? Looks better then the original one! I didn't know I could easily change them. I tried different font yesterday and like it.
