After getting the display and worker up and running I started down the path of training my model for keyword recognition. Right now I've settled on the wake words `Hi Smalltalk`. After the wake word is detected the model will then detect `silence`, `on`, `off`, or `unknown`.
My starting point for training the model was the [`micro_speech`](https://github.com/tensorflow/tensorflow/tree/master/tensorflow/lite/micro/examples/micro_speech) and [`speech_commands`](https://github.com/tensorflow/docs/blob/master/site/en/r1/tutorials/sequences/audio_recognition.md) tutorials that are part of the Tensorflow project. One of the first things I noticed while planning out this step was the lack of good wake words in the speech command dataset. There are [many](https://github.com/jim-schwoebel/voice_datasets) voice datasets available online, but many are unlabeled or conversational. Since digging didn't turn up much in the way of open labeled word datasets I decided to use `on` and `off` from the speech commands [dataset](https://ai.googleblog.com/2017/08/launching-speech-commands-dataset.html) since that gave me a baseline for comparison with my custom words. After recording myself saying `hi` and `smalltalk` less then ten times I knew I did not want to generate my own samples at the scale of the other labeled keywords.
Instead of giving up on my wake word combination I started digging around for options and found an interesting [project](https://github.com/JohannesBuchner/spoken-command-recognition) where somebody had started down the path of generating labeled words with text to speech. After reading through the repo I ended up using [espeak](http://espeak.sourceforge.net/) and [sox](http://sox.sourceforge.net/) to generate my labeled dataset.
The first step was to generate the [phonemes](https://en.wikipedia.org/wiki/Phoneme) for the wake words:
$ espeak -v en -X smalltalk
sm'O:ltO:k
I then stored the phoneme in a word file that will be used by `generate.sh`.
$ cat words
hi 001 [[h'aI]]
busy 002 [[b'Izi]]
free 003 [[fr'i:]]
smalltalk 004 [[sm'O:ltO:k]]
After modifying `generate.sh` from the spoken command repo (eliminating some extra commands and extending the loop to generating more samples) I had everything I needed to synthetically generate a new labeled word dataset.
#!/bin/bash
# For the various loops the variable stored in the index variable
# is used to attenuate the voices being created from espeak.
lastwordid=""
cat words | while read word wordid phoneme
do
echo $word
mkdir -p db/$word
if [[ $word != $lastword ]]; then
versionid=0
fi
lastword=$word
# Generate voices with various dialects
for i in english english-north en-scottish english_rp english_wmids english-us en-westindies
do # Loop changing the pitch in each iteration
for k in $(seq 1 99)
do
# Change the speed of words per minute
for j in 80 100 120 140 160; do
echo $versionid "$phoneme" $i $j $k
echo "$phoneme" | espeak -p $k -s $j -v $i -w db/$word/$versionid.wav
# Set sox options for Tensorflow
sox db/$word/$versionid.wav -b 16 --endian little db/$word/tf_$versionid.wav rate 16k
((versionid++))
done
done
done
done
After the run I have samples and labels with a volume comparable to the other words provided by Google. The pitch, speed and tone of voice changes with each loop which will hopefully provide enough variety to make this dataset useful in training. Even if this doesn't work out learning about `espeak` and `sox` was interesting. I've already got some future ideas on how to use those. If it does work the ability to generate training data on demand seems incredibly useful.
Next up, training the model and loading to the ESP-EYE. The code, docs, images etc for the project can be found [here](https://git.sr.ht/~n0mn0m/on-air) and I'll be posting updates as I continue along to [HackadayIO](https://hackaday.io/project/170228-on-air) and this blog. If you have any questions or ideas reach [out](mailto:alexander@unexpextedeof.net).
Alexander Hagerman
