Hackaday.io Hackaday.io
Sign up Log in
LM317 Output Current Hack!
I discuss two methods of LM317 current boosting, using power PNP and NPN pass transistors
hesammoshirihesam.moshiri
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.9k views
1 comments
1 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 1
View Gallery
1.9k
1
1
1
Team (1)
  • hesammoshirihesam.moshiri
Join this project's team
  • Article
hardware
LM317 LM317 current boost LM317 variable
This project is submitted for
  • Hackaday.com Tip Line
This project was created on 03/12/2020 and last updated 7 years ago.
Description
LM317 is one of the most popular adjustable regulator chips. The output voltage of the regulator can be adjusted from 1.25V to 35V. However, the chip can deliver currents up to 1.5A which is not enough for some power applications. In this article, I will discuss two methods of LM317 current boosting, using power PNP and NPN pass transistors.
Details
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
sara_queen wrote 03/14/2020 at 15:51 • point
nice work and explanation
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "LM317 Output Current Hack!", please tell us the reason.
Send message
Remove Member
