• 1
    Print
    Just print the 2 STL file.
  • 2
    Make the electronic
    Solder the battery to B+ and B- to the TP4056, Then solder the GND.- of the fan to the the TP4056,
    Solder the ON/Off button to the fan, then solder the on/off to the Volt.+ TP4056.
  • 3
    Attach the fan with M3 nuts and screw
    Attach them to the case
