Glixie... A glow in the dark Nixie
A faux nixie tube style display with an array of 7 LED's. Creating a 5x7 character matrix.
A Nixie tube style display with an array of 7 LED's. Creating a 5x7 character matrix.
I really like Nixie clocks (who doesn't?) but I wanted to create my own. And because I don't want to tinker with high voltage and a Lixie has already been done... I created Glixie a glow in the dark Nixie tube.
This is a spin-off of a larger project I'm currently working on, and because I always wanted to have a real nixie clock, I created a new type of Faux-Nixie.
It has an array of 7 leds which create a 5x7 matrix with which you can display any latin charater, so you're not limited to only digits.
Pros:
  • Can display any alpha-mumeric character
  • No high voltage
Cons:
  • Not a real Nixie
  • Cannot be used at high speed or for seconds.
  • 1 × Laser cut plywood and acrylic
  • 1 × 28-BYJ48 stepper motor
  • 1 × f623z Bearing
  • 1 × Brass stand-offs 50mm
  • 7 × UV LED
  • First tests
    SephenDeVos03/13/2020 at 12:18 0 comments
    It's Alive! Sort off...
  • Build
    SephenDeVos03/13/2020 at 12:05 0 comments
    The idea which used a 6x7 matrix
    First prototype with special glow in the dark paint made with "Lit" A special Glow in the dark powder, made by Culture Hustle
    Some components
    Placement of the stepper
View all 2 project logs
Jim Thompson wrote 09/12/2020 at 18:28 point
Really great project.  But "Glixie"???  I guess if you can call a wheeled vehicle a "hoverboard" because of some remote resemblance, then you can call a piece of particle board a "Pleenex", because it's a planar sheet of wood fibers, and you can call a piece of chalk a "Chixie", because it is capable of producing graphical representations of numbers.  Kids these days.
SephenDeVos wrote 09/13/2020 at 08:14 point
Thanks, i think... :). That's exactly what the name implies. I feel the same about all the ...uino products.
Paul Andrews wrote 03/19/2020 at 14:59 point
Great. Another project to add to the list!
ajlgrant wrote 03/19/2020 at 10:50 point
This is superb, I had similar ponderings many years ago and bought  a roll of phospherescent vynal and a reel of SMD UV LEDs but that is about as far as it got before work and life descended. This is really nice though, thanks for the inspiration!
Robb Smith wrote 03/18/2020 at 22:38 point
Excellent design work!  I'm hoping to merge your idea of using LEDs to make dots with this guy's bicycle mounting technique:  https://www.youtube.com/watch?v=l6YRsurIQMQ
Andy Callaway wrote 03/18/2020 at 18:27 point
Cool. I was thinking of doing something like this.
Dan Maloney wrote 03/16/2020 at 19:49 point
Great look, love the fact that you can already see the glow fading on the dots forming the leading edge. And "Glixie" is a great name too!
SephenDeVos wrote 03/17/2020 at 16:06 point
Thanks, The afterglow is a bit of a nuisance, especially when a digit is displayed over a previous different one. So i'm now trying to get the timing/intensity right in different lighting conditions and testing the use of filters.
Stefan Krüger wrote 03/18/2020 at 20:40 point
really nice work!
i like your wood design!
you can 'erase' the glow with infrared light.
just add a line of IR-LEDs before your UV ones..
i tested this some days ago with  some old glow in the dark stars and it is really a fascinating effect!!
(i tested this after i saw the https://hackaday.io/project/169462-uv-glow-in-the-dark-plot-clock and thought about building my own ;-)...)
Mike Szczys wrote 03/13/2020 at 19:09 point
That is a superb effect! I've seen numerous moving phosphorescent display but the drum effect has one of the best overall looks. Awesome :-D
SephenDeVos wrote 03/17/2020 at 16:01 point
Thanks!
