A few UX improvement
A project log for BlueRetro
Multiplayer Bluetooth controllers adapter for retro video game consoles
jacques-gagnonJacques Gagnon 06/24/2021 at 21:090 Comments
I redesigned how the LED and BOOT switch are used, holding it 3 sec start inquiry scan (and LED start to pulse), short press while inquiry scan is on cancel it (and LED stop glowing), one short press outside of inquiry scan kick out all controllers as before. The LED being solid on still indicate that an error occurred. Holding the switch 10 sec will factory reset the adapter to default config and clear the Bluetooth keys.
I also added the option to disable the automatic inquiry while no controller present via the web config.
See v0.18 release.
