Backplane for DIY NAS
Sata backplane design to go in my DIY NAS case
This is the backplane design that go in my custom NAS server case : <a target="_blank" rel="noopener noreferrer" href="https://www.thingiverse.com/thing:4151400It&apos;s">https://www.thingiverse.com/thing:4151400It&apos;s</a> just a board that facilitate installation of HDDs in the case and cable management.I&apos;ve design it using Kicad 5.1.4.
The backplane is made to be integrated in my DIY NAS server case, behind the HDD cage.
Each backplane is design for 3 HDDs powered by 2 SATA power connectors and you need 2 of them for my DIY case.
Power and data connectors are on one side and SATA headers on the other.
Here is the result :
backplane_kicad_project.zip
Kicad project
x-zip-compressed - 216.98 kB - 03/19/2020 at 12:04
Download
gerber files.rar
Files to use for manufacturing
RAR Archive - 74.58 kB - 03/19/2020 at 11:25
Download
  • 3 × SATA data connector THT sata connector for data
  • 3 × SATA header THT 7+15 pins sata socket
  • 2 × SATA power connector THT sata power connector
  • 6 × 1206 SMD capacitor 1206 4.7uF 50V SMD capacitor
View project log
  • 1
    Soldering instructions
    I recommand using hot air and solder paste to install every componants as the pads are quite small to use a soldering iron.
    Begin with the 6 capacitors and then install every connectors.
View all instructions
frontpage32 wrote 04/04/2024 at 03:18 point
I love this. Question though how hard would it be to increase this to a 5 disk?
Andrea Colombo wrote 01/13/2021 at 13:43 point
I've seen your case on Thingiverse previously and now I'm stumbling upon your pcb here on Hackaday. You did an awesome job all around in your build. I'd like to replicate a similar PCB for my own needs so thanks for the idea.
What are the capacitors there for?
Also, the snake-like pattern of the data traces to make them the same length, is it a feature of KiCad or did you make it manually?
axf33480 wrote 09/25/2020 at 13:12 point
bonjour ou vous trouver les composant  connecteur sata alim sata donne et les condensateurs
Tom Nardi wrote 03/28/2020 at 16:19 point
Love it, makes for a very sleek install.
