New Design Revision
A project log for 3D Printable Sealing Face Mask (Experimental)
Open source 3D printable mask that's been designed as a proof of concept to see if a well fitting mask can be made
SupercellSupercell 03/21/2020 at 17:400 Comments
Adjusted the overall shape of the mask for better fit. Should have a more close fit around the cheek as the previous version was a bit large. Adjusted the thickness of walls to improve overall strength and printability
