The Simplest way to Drive your Brushless Motor using SOLO
A project log for SOLO, A Motor Controller for All Motors
SOLO is a Motor Controller designed to easily run most types of electrical motors, DC, BLDC, PMSM and ACIM. it's easy to use and versatile.
miladmilad 08/11/2020 at 18:500 Comments
Here we try to show how to simply drive your brushless motors from any kind ( BLDC, PMSM, BLAC) using SOLO in totally manual mode, without the need to have any external modules like Arduino or Raspberry Pi. Here SOLO will control two different types of BLDC motors one with 20kHz of switching frequency at the output and the other one which is a very low inductance motor with 80kHz of switching, Both motors are controlled in Sensorless Speed mode using field-oriented control methodology. The article on our website: - https://www.solomotorcontrollers.com/control-speed-brushless-motor-manually-closed-loop-sensorless-mode/
