Speed Control of an AC Induction Motor using SOLO in Manual and Digital mode ​
A project log for SOLO, A Motor Controller for All Motors
SOLO is a Motor Controller designed to easily run most types of electrical motors, DC, BLDC, PMSM and ACIM. it's easy to use and versatile.
miladmilad 10/12/2020 at 21:210 Comments
Here we are intending to show how to control the speed of an AC Induction motor with Squirrel cage design using SOLO. You will see how this operation is done in a sensor-less mode in a Vector control manner (FOC), firstly with only two potentiometers and then using SOLO Motion Terminal using the USB.
