SIMPLEST WAY TO CONTROL A FAST BRUSHLESS MOTOR WITH RASPBERRY PI USING SOLO [+ CODE]
A project log for SOLO, A Motor Controller for All Motors
SOLO is a Motor Controller designed to easily run most types of electrical motors, DC, BLDC, PMSM and ACIM. it's easy to use and versatile.
miladmilad 06/08/2021 at 06:590 Comments
We just published a new article, demonstrating the Speed controlling of a high-speed Brushless motor using Raspberry Pi and SOLO by coding in Python.
There we show how easily you can interface Raspberry Pi to SOLO for Closed-loop controlling of a BLDC reaching up to 30,000RPM in sensor-less mode with Field Oriented Control.
https://www.solomotorcontrollers.com/simplest-way-to-control-a-brushless-motor-with-raspberry-pi/
