Riveting Results
A project log for COSV - Cam Open Source Ventilator
Roller cam based portable BVM ventilator.
daren-schwenkeDaren Schwenke 10/23/2020 at 19:480 Comments
The arm prints and the corresponding paddles/pivots did not turn out perfectly, but they will still work regardless and I suppose that is part of the point.
I decided to use the post out of a rivet I had here as my retaining pin.
