Door handle ring
Make a plastic ring used to avoid contact with potentially corona virus contaminated door handles.
Public Chat
This is a very simple anti corona virus device hack. Use a hacksaw to cut rings off a plastic pipe, I had a piece of 50 mm PE pipe available. Use the ring to operate door handles. Maintains a clean outer surface and a potentially contaminated inner surface (or visa versa). After a little training I can move from home to my office without touching any surfaces. I wash with soap while washing my hands.
My ring is about 25 mm long, short enough to allow for getting a grip on curved handles and easy to keep in pockets, long enough to get a firm grip.
I don't have any door knobs where I live. I assume the end of a piece of pipe can be used to turn door knobs. For this, one pipe end must have higher friction, perhaps a rubber glove finger can be pulled over on end?
Clintannon wrote 01/12/2023 at 00:31 point
Door handle ring is used to connect or hold a door handle. Door handle ring can assist in installing, replacing, or removing door handles. Door handle ring can also be used to install new door handles go now and make it quick.
Dan Maloney wrote 03/26/2020 at 19:48 point
Clever idea. I miss having lever knobs on doors - had them in my old house and they were great for using an elbow or a foot to open the door even with your hands full.
