Conforming Face Mask Cover Frame
Mask design based on using a cloth, tissue or filter material covering the mouth and nose, and having a frame to hold in place
Design based on the idea of simply using a cloth, fabric, tissue or filter material covering the mouth and nose, and having a frame to hold it in place. There are already existing designs available such as the "DIY Face Mask" by 2ROBOTGUY on Thingiverse, however, I decided to reuse one of my existing CAD models to make a more conforming version of the concept. Also possible to use on top of a surgical mask to provide a tighter fit.
Caution
This design should not be used to replace an existing mask or respirator. The design should not be used as an N95 respirator and should not be used to replace one. Possible use of materials may be harmful. Do not use the design as a medical device or in any situations in which it may cause or result in injury. I can not be liable to any issues cause by the use of my design
shell.stl
Print file
Standard Tesselated Geometry - 7.63 MB - 03/27/2020 at 05:28
Download
shell_no_slit.stl
No slit of elastic band print file
Standard Tesselated Geometry - 7.68 MB - 03/27/2020 at 05:28
Download
stp - 1.24 MB - 03/27/2020 at 05:28
Download
shell.stp
CAD file
stp - 1.39 MB - 03/27/2020 at 05:28
Download
