ePaper fridge magnet
Put your images on a SD card and display it on your fridge
Single board for controlling 2.7 inch epaper displays. Load Images from micro SD card. The controller chip is a msp430g2553 from TI with a 32khz external crystal .Compact 3D printed frame for the 2.7 inch epaper display.
Main features
  • Light compact 3d print design with magnets.
  • Use a single CR2032 coin cell that will last longer than a year.
  • Put image files on SD card (SD card needs to reformatted).
  • Setup files to set update frequency and more.
  • Easy to reprogram using a launchpad.
  • Code is writing in Energia, a modified version of the Arduino IDE
Current software features
  • Load Setup on startup.
  • Intervals are set in 2 minute interval. For ones a day update use 720.
  • Low Battery voltage detection.
Hardware
  • Display: 2.7 inch b/r/w epaper display. More detail  here .
  • MCU: Texas Instruments MSP430G2553IPW20R  (TSSOP-20)
  • 32.768 kHz crystal for accurate time keeping.
  • Mirco SD card socket.
  • 3.3v boosting using AAT1217-3.3. SD cards not happy with less voltages.
  • The necessary components plus 24 Position FFC, FPC Connector for the epaper display.
  • Extra reset switch and mode switch.
  • Header to flash the MSP430 and serial (UART) for debugging.
Power usage
  • Standby current average 4.3 uA . When keeping time.
  • Update power consummation  aground 100 uAh . When refresh screen with new picture.
  • Battery will easily  last over a year if update once a day.
  • Because of  the SD card power spikes, need a good quality make and will not drain to empty before read failures.
  • 4 Color Gray
    Waldo Wolmarans • 11/10/2020 at 11:38 • 0 comments
    I'm updating the source code to display 4 color gray images using the standard b/w 2.7 inch e-paper screens .  The black and red screens also can display gray scale but the gray is very light.
    For now it will be a separate branch on git . But I plan to make it a config option in the SETUP.TXT file.
    Here is a couple samples.
View project log
Dan Maloney wrote 03/26/2020 at 19:49 • point
No, I did not know that about macadamia nuts. So thanks for the tip, and for the project - a customizable fridge magnet would be just the thing for my wife.
Ken Yap wrote 03/26/2020 at 21:53 • point
Chocolate too.
Waldo Wolmarans wrote 03/27/2020 at 10:33 • point
The customizable part is also important , thanks for the tip.
