Hackaday.io Hackaday.io
Sign up Log in
3D printable Vacuum Cleaner
Powerful 3D printed Vacuum Cleaner. Almost everything is printed except motor, electronics and some screws. Motor & Electronics cost ~ 10$
marko-antonmarko anton
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
7 comments
13 followers
  • Description
  • Details
  • Files 7
    • View all
  • Components 4
    • View all
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 7
View Gallery
878
7
13
16
Team (2)
  • marko-antonmarko anton
  • aleksandrAleksandr
Join this project's team
hardware
ongoing project
3D printed vacuum vacuum cleaner cleaner Motor ac/dc recycle repairable
This project was created on 03/26/2020 and last updated 4 years ago.
Description
Did you ever wanted to make something really useful with 3D printer. Here is a vacuum cleaner.All you need is RS 545 motor and AC-DC converter, few screws and a filter.Other advantages of this vacuum cleaner other than being printed and cheep are, it can be repaired and upgraded.In future we will release a Vacuum cleaner on battery and vacuum cleaner for car that works on car power socket.https://youtu.be/BF4jt5-ldB8https://youtu.be/noaLUsivBwE
This work is licensed under a Creative Commons Attribution-ShareAlike 4.0 International License.
Files
openSucker_v0.1.FCStd
x-zip-compressed - 26.36 MB - 02/12/2021 at 20:02
Download
filter.stl
Standard Tesselated Geometry - 2.15 MB - 03/29/2020 at 08:29
Download
Handle.stl
Standard Tesselated Geometry - 7.75 MB - 03/26/2020 at 19:32
Download
Container.stl
Standard Tesselated Geometry - 4.62 MB - 03/26/2020 at 19:31
Download
Rotor.stl
Standard Tesselated Geometry - 3.08 MB - 03/26/2020 at 19:31
Download
View all 7 files
Components
  • 1 × Motor RS-545 12V
  • 1 × AC-DC converter 220 AC to 12 V
  • 1 × Slide button
  • 1 × Wires
Project Logs
Collapse
  • FreeCAD project uploaded
    marko anton • 02/12/2021 at 20:05 • 0 comments
    Uploaded FreeCAD project file. Plan is to make project parametric.
  • Initial publish
    marko anton • 03/29/2020 at 08:38 • 0 comments
    First stl files, some pictures and description
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
bmurch22 wrote 06/01/2022 at 20:30 • point
It's good to see the 3D project use it as a house cleaning device for sewage clean up households. I like it.
oksanazya wrote 11/27/2021 at 17:20 • point
I have tried the same way to make the 3D printed vacuum for my program. Learn more about it.
emisolersa wrote 03/25/2021 at 10:58 • point
it looks like a very different and unique idea I watched some of more similar projects here on https://cleanthese.com/
Florian Festi wrote 03/29/2020 at 21:40 • point
Nice project. But why not use a battery from am electric drill. As it is 3d printed it should be easy to support the most common brands.
fwacer wrote 03/30/2020 at 01:31 • point
Battery would likely increase the weight quite a bit, and would require more support structure (if I had to guess), which costs more filament. Certainly still an interesting modification idea
marko anton wrote 03/30/2020 at 11:38 • point
There is a plan to make a new version with a battery from a drill.  Stay tuned ;)
Florian Festi wrote 04/01/2020 at 07:59 • point
Nice!
The battery probably needs to go underneath the grip so it stays balanced in the hand.  You could have a mounting spot for various adapter plates there. Guess some flat, boxy batteries work best. Unless you want to have a stick battery that fits into the grip itself.
The 2015 Hackaday Prize
Custom electromechanical motor that can be printed using any 3D printer, some coil, maybe magnets and a controller.
Project Owner Contributor
3D Printed Parametric Motor
solenoidSolenoid
The first Submarine of the ESME
The SubesTM
matthiasMatthias
Stepper-Driven, MIDI-Controlled, Tonewheel Robot made with laser cut sheet metal tonewheels and custom-wound pickups
Hammond-Inspired Tonewheel Organ Robot
themixedsignalTheMixedSignal
This is a project in the final year student's graduation thesis defense.
3D file DIY Servo motor model
lossstarrylossstarry
Going up?
© 2025 Hackaday
Yes, delete it Cancel
You are about to report the project "3D printable Vacuum Cleaner", please tell us the reason.
Send message
Remove Member
