Bonus track
A project log for Discrete component object recognition
Inspired by a recent paper, the goal is to develop a system that can recognize numbers from the MNIST database without a microcontroller
ciplionejciplionej 04/07/2020 at 15:560 Comments
Whilst thinking about the results obtained and licking my LDR inflicted wounds, I thought about a way to implement this object recognition system that would not involve fiddly hard to measure intensity levels.
It occurred to me that I could change the intensity levels from 256 shades of grey, to a binary 0/1, i.e. if the intensity was higher than 127, then 1, else 0. In this way, the pictures become black and white, instead of grey shades, and we have new implementation possibilities.
Up til now we needed to measure an intensity, translate it onto an analog signal (voltage), compare it to the reference voltage and get a digital signal (In each split node: Yes/No, Left/Right, etc).
Now, we have a binary signal, we do not need to fiddle with intensity levels, analog signals, we do not need voltage comparators.
Heaven.
Below is a decision tree modeled on the same MNIST dataset but using the new binary system instead of the intensity level. The accuracy is in line with the models obtained in the Minimum Model task using all the default settings in Rstudio and the rpart package.
The confusion matrix below shows that a lot of digits get miss-classified. Nevertheless, this model has not been optimized nor iterated in any way. The columns represent the digit shown and the rows represent how they were classified.
       0    1    2    3    4    5    6    7    8    9
  0  757    4    1   28    6   51  149  131   32   23
  1    6 1036   17  151    0    7   18   67   55    1
  2  120   78  458   26   39    2  168  110  169   22
  3   43   23   14  864   24   65    5  129   47   31
  4    3   27    5   31  665   28   64  220   23   88
  5  118   30   20  166   72  211   35  215   88  128
  6   67   35   50   24  102   19  585   61  268   24
  7    4   28   10   21   31   57   42  961   13   31
  8   36  143   51   68   19   34  205  146  391   40
  9    5   40    2   64   91  154   51  330   19  462
 The overall accuracy was just over 53% and the individual accuracy is shown in the table below.
        0         1         2         3         4         5         6         7         8         9
0.4779040 0.5866365 0.3362702 0.4736842 0.4323797 0.1406667 0.2966531 0.3686229 0.2116946 0.2876712
There is a huge improvement potential with this change.
The simplified system is depicted below. All we'd need to implement this object recognition system is:
  1. 11 LDRs
  2. 11 NOT gates (can be built using 1 transistor and 2 resistors per gate)
Adding complexity
By changing the complexity parameter (cp), we can increase the accuracy significantly, at model complexity cost. The plot below shows the increase in accuracy as we reduce the cp value.
As cp decreases so does the number of splits. A model with a cp of 0.005 for example, has a sizeable jump in accuracy to 62 %, with a still manageable 24-node tree.
A step up to 0.001, increases accuracy to a respectable 74 %, with a 91-node decision tree.
There's a clear trade-off between complexity and accuracy, though more specific optimizations could potentially be carried out in order to obtain a better accuracy without a high complexity penalty.
Conclusion
We have reached a solution that could allow us to implement a really simple object recognition system using readily available components.
The accuracy could be considered to be within the goals of the project at a respectable 75 % plus if we're willing to live with the complexity level.
As a proof of concept this project allows for potential improvements by using more complex decision trees and replacing more elaborate, slower and less power efficient systems in Object Recognition applications.
