Components Required:
- Mercury Switch/ Tilt Sensor
- Arduino UNO
- Buzzer
- LED
- Resistor - 220 ohm
- Breadboard
- Connecting wires
Schematic:
Connecting the circuit:
To connect a Tilt sensor with the Arduino, it requires 5v dc input to operate. That 5v is supplied using Arduino UNO and the output of Tilt sensor is taken at PIN 4 of the Arduino. LED is connected with the PIN 2 of the Arduino UNO with 220-ohm resistor to limit the current to a safe value. And, the buzzer is directly connected to the PIN 3 of the Arduino UNO.
Testing the Sensor:
After connecting everything together and uploading the code to arduino IDE , whenever you will tilt the sensor then the buzzer will beep and the LED will blink according to the rotation of sensor.
