Github PCB files
A project log for VISP - Ventilator Inline Sensor Package
Bidirectional flow (volume), pressure, and temperature sensing in a single inexpensive I2C/SPI package.
Daren SchwenkeDaren Schwenke 04/06/2020 at 20:490 Comments
Copy/paste courtesy of @Steven.Carr.  These are in-progress files, so don't go spinning up 1000 of them and expect nothing to change.  :)
Files are up on Github here.
VISP-BREAKOUT is a small single sided breakout board with the 4 sensors in the right places brought out to SMD pads for soldering wires
VISP-I2C-DUAL is a small board with 4 sensors, and a 6-wire interface.   2-channels of I2C and VCC+GND
VISP-I2C-MUX is a 4-wire I2C interface with a I2C bus multiplexer to switch between the 2 sets of I2C sensors
VISP-I2C-XLATE was our first design.   Single 4-wire I2C interface with all of the sensors visible on the same bus
VISP-SMART is a unreviewed completely 3v3 design with an atmega328 on board and useful pins brought out to SMD solder pads on the back.
VISP-SPI is an 8-wire interface to the sensors, using a 3-to-8 decoder to convert A0:2 into a Chip Select (where address 000 is unselected so the bus can be shared.  8 wires so an RJ45 jack can be used at the core controller for connectivity)
