Frame Script
A project log for Bike Frame Builder
A Grasshopper script which generates bicycle frame-set geometry based on input variables for the home builder.
david-troetschelDavid Troetschel • 03/29/2020 at 22:43•0 Comments
I built the frame script from the cranks out; there are several systems which are used to communicate frame dimensions so this is just one approach. As of V6 you can expect a considerable amount of trial and error but the key component locations are modeled.
Imputing a sample table like:
You get a result of:
Forget the extra tubes, think of them as boundaries.
There is a pretty big error right now, this system relies on fork length to drive the top tube length. But that's the status of the builder so far, working on V7 now.
