Damned RPi3 !
A project log for C GPIO library for Raspberry Pi
Lightweight GPL'd #include for your C programs
Yann Guidon / YGDESYann Guidon / YGDES 02/16/2017 at 17:340 Comments
Trying to turn a LED on with the lib on a RPi3 using the slim 2017-01-11-raspbian-jessie-lite.zip image.
GPIO_on.sh and GPIO_off.sh work but not the C code.
The culprit is found easily because detect_GPIO_BASE.sh doesn't return anything (despite being on RPi3).
pi@raspberrypi:~/ $ cat /proc/iomem
00000000-3affffff : System RAM
  00008000-007ea673 : Kernel code
  00862000-009901eb : Kernel data
3f007000-3f007eff : /soc/dma@7e007000
3f200000-3f2000b3 : /soc/gpio@7e200000
3f201000-3f201fff : /soc/uart@7e201000
3f300000-3f3000ff : /soc/mmc@7e300000
The expected keyword is not found ! Instead of bcm2708_gpio, I get /soc/gpio
Another thing is that I forgot to enable the device tree... But a keyword can be added:
grep -E '/soc/gpio|bcm2708_gpio' /proc/iomem
Result:
pi@raspberrypi:~/projets/files $ . detect_GPIO_BASE.sh
GPIO_BASE=-DGPIO_BASE=(0x3f200000)
pi@raspberrypi:~/projets/files $ echo $GPIO_BASE
Seems legit... But I still have to test with the device tree.
20180118 : don't forget to run the detection script as ROOT !
pi@raspberrypi$ sudo detect_GPIO_BASE.sh
Raspbian now returns invalid values when run as user:
 $ cat /proc/iomem
00000000-00000000 : System RAM
  00000000-00000000 : Kernel code
  00000000-00000000 : Kernel data
00000000-00000000 : dwc_otg
(I should update my files......)
