AutoCAD DXF - 75.27 kB - 04/08/2020 at 20:46 |
Adobe Portable Document Format - 13.75 kB - 04/08/2020 at 20:46 |
AutoCAD DXF - 78.34 kB - 04/08/2020 at 20:46 |
Adobe Portable Document Format - 13.59 kB - 04/08/2020 at 20:46 |
300x200-strap-standalone.dxfTwo part version, which can fit on a 300 mm x200 mm sheet (strap part)AutoCAD DXF - 80.42 kB - 04/08/2020 at 20:59 |
300x200-visor.dxfTwo part version, which can fit on a 300 mm x200 mm sheet (visor part)AutoCAD DXF - 42.98 kB - 04/08/2020 at 20:59 |
300x200-strap-standalone.pdfTwo part version, which can fit on a 300 mm x200 mm sheet (strap part)Adobe Portable Document Format - 13.97 kB - 04/08/2020 at 20:59 |
300x200-visor.pdfTwo part version, which can fit on a 300 mm x200 mm sheet (visor part)Adobe Portable Document Format - 12.78 kB - 04/08/2020 at 20:59 |
Untested-DiecutMethod - SiliconRubber.dxfThis is the latest version, i was making the modification based on my latest production, but haven't had the time to test it. This means, in theory, this could be the best, but there is also a risk with it.AutoCAD DXF - 77.98 kB - 04/05/2020 at 10:31 |
Untested-OnePiece-DiecutMethod - RubberBand.pdfThis is the latest version, i was making the modification based on my latest production, but haven't had the time to test it. This means, in theory, this could be the best, but there is also a risk with it.Adobe Portable Document Format - 13.90 kB - 04/05/2020 at 10:31 |
Untested-OnePiece-DiecutMethod - RubberBand.dxfThis is the latest version, i was making the modification based on my latest production, but haven't had the time to test it. This means, in theory, this could be the best, but there is also a risk with it.AutoCAD DXF - 75.20 kB - 04/05/2020 at 10:31 |
Untested-DiecutMethod - SiliconRubber.pdfThis is the latest version, i was making the modification based on my latest production, but haven't had the time to test it. This means, in theory, this could be the best, but there is also a risk with it.Adobe Portable Document Format - 13.72 kB - 04/05/2020 at 10:31 |
Tested-DiecutMethod - RubberBand.dxfThis is the latest, printed version, no long-term testing.AutoCAD DXF - 78.39 kB - 04/05/2020 at 10:32 |
Tested-DiecutMethod - RubberBand.pdfThis is the latest, printed version, no long-term testing.Adobe Portable Document Format - 13.83 kB - 04/05/2020 at 10:31 |
Tested-DiecutMethod - SiliconRubber.dxfThis is the latest, printed version, no long-term testing.AutoCAD DXF - 77.36 kB - 04/05/2020 at 10:32 |
Tested-DiecutMethod - SiliconRubber.pdfThis is the latest, printed version, no long-term testing.Adobe Portable Document Format - 13.53 kB - 04/05/2020 at 10:31 |
License.txtAttribution-NonCommercial 4.0 International (CC BY-NC 4.0)plain - 17.33 kB - 04/05/2020 at 09:59 |
Shield-2PARTS ONLY.pdfThis is the version, which we produced around 6k, for lasercut.Adobe Portable Document Format - 7.25 kB - 03/30/2020 at 16:04 |
HeadShield v1 (3 parts version).pdfThe very first version of the shield, this is on the pictures, and got distributed over the local hospitalsAdobe Portable Document Format - 13.96 kB - 04/15/2020 at 17:37 |
