Pushed firmware update to github.
A project log for ddPrint - Adding Process control to FDM printers
ddprint: a fdm 3d printer firmware and printing system
erwin-riegerErwin Rieger 06/08/2021 at 17:260 Comments
Pushed a new firmware branch *fix-avr* to github. The JennyPrinter port made the avr/atmega side to slow.
Changes are:
* Integer math instead of floating point.
* Reworked usb-serial interface: store 512byte blocks.
* Removed compression with zlib, the avr has not enough cpu cycles.
* Experiment: auto-baudrate. Switch between 1000000, 500000 and 250000 baud.
* SDReader: double-buffering.
* Many other improvements and cleanup.
So for now, fix-avr is the branch to use for avr/atmega based printers and master is for
the stm32 JennyPrinter. Branch fix-avr has will be merged into master.
