For Cheap Electrnoic Components / IC's / Sensors / Modules
Visit ► https://www.utsource.net/
Today in this video tutorial I am going to show you Step by Step How to make a simple water level indicator circuit using 74hc147n & cd4511 IC
You, Will, Find Full Project Description & All Useful Material Including
• Circuit Diagram / Schematic
• Hardware / Component List
• Codes / Algorithm
• Datasheet
• Pin Configuration Etc
AT ► https://circuits-diy.com/how-to-make-a-water-level-indicator-using-cd4511-&-74174-ic/
Thanks for Watching It.
Hardware Required
For Cheap Electronic Components Visit : Utsource.net
Useful Steps
Solder 7 Segment common cathode
Solder 470 Ohm resistors
Solder 5v Regulator
Solder CD5411 IC base
Solder BC547 Transistors
Solder 10k Resistors
Solder wire to all levels
Circuit Diagram
