ESP-01 Breadboard Adaptor
A breadboard adaptor so you can prototype your ESP-01
Starting from
$4.00
microInventions has 190 orders / 22reviews
Ships from Portugal
If you ever tried to tinker around the ESP8266-01 you've probably realised you can't plug it in directly on your breadboardThen you also realized it doesn't run on 5V, so you need to convert the voltage down to 3.3V.And afterwards you realized your ESP doesn't boot up because of initial current spike.Well this board solves all of these problems.
Here are its specs:
  • 3.3V Regulator SPX3819
  • 40uF Capacitance on Power Lines
  • Power LED
  • GPIO D2 LED
  • RST Switch
  • Boot Switch
Adobe Portable Document Format - 20.93 kB - 04/01/2020 at 21:38
Preview
Download
PCB Gerber.zip
Gerber Files
x-zip-compressed - 37.29 kB - 04/01/2020 at 21:38
Download
  • 1 × SPX3819 Power Management ICs / Linear Voltage Regulators and LDOs
  • 4 × 10uF 0805 Ceramic Capacitor
  • 4 × 10k 0605 Resistor
  • 2 × 0605 Red Led
  • 2 × SPST Switches
View project log
Kashyapkoshti wrote 04/07/2020 at 06:57 point
Why didn't you add logic level converters in it, so it can easily programmed with Arduino?
Miguel Reis wrote 04/07/2020 at 09:54 point
The esp can easily take 5v on the logic pins so there is no need
Kashyapkoshti wrote 04/07/2020 at 10:07 point
did you mean to say that tx /rx pins pf esp01 can handle 5v ?
Miguel Reis wrote 04/07/2020 at 18:18 point
Yes
Kashyapkoshti wrote 04/08/2020 at 06:20 point
but i read in data sheet of esp01 that maximum Voltage of 3.3 volts for any pins
Miguel Reis wrote 04/08/2020 at 14:30 point
https://hackaday.com/2016/07/28/ask-hackaday-is-the-esp8266-5v-tolerant/
Check this thread. I also speak from experience using the esp8266
