Single Piece Laser Cut Face Shield PPE
Single piece, all laser cut design that assembles with just double sided tape and 3/4" Rubber Strap
Single piece, laser cut face shield/mask that cuts and assembles in minutes. Assembled simply with two squares of double sided tape, lightweight and hygienic.
Lays and ships flat until final assembly, no tools required. No fatigue, wear marks or heft. It feels like air! (Cut from 0.4-0.6mm PET sheet or similar material.) Easy to adjust rubber strap attachment.
Designed to be laser cut out of 0.4mm-0.6mm PET Sheet or similar material. Attachment to rubber strap uses a simple pinching mechanism. See video for instructions.
This face shield design is not endorsed by or approved by any healthcare institution or regulatory body and should only be used as reference and for personal use, at your own risk.
Flat_FaceShield_Rev1.ai
Adobe Illustrator AI File for Laser Cutting
postscript - 1.43 MB - 04/03/2020 at 22:48
Download
Flat_FaceShield_Rev1.dxf
DXF File for Laser Cutting
AutoCAD DXF - 78.87 kB - 04/03/2020 at 22:48
Download
  • 1 × 0.4-0.6mm Clear PET sheet or similar material
  • 2 × 1x1" Squares of VHB Double Sided Tape or similar
  • 1 × 3/4" wide Elastic Strap
  • 1
    Instruction Video
    Video contains assembly instructions and other details
View all instructions
davedarko wrote 04/06/2020 at 07:45 point
I see a lot of criticism floating around of masks that aren't closed above the eyes. You might want to move the mount down a bit, so you get more protection up there. Weird times we live in.
