CBJT Logic V2
A Complementary Bipolar Junction Transistor Logic family
This version of CBJT is my experimental logic family that is 5V CMOS compatible but requires dual power supply (+-2.5V). Resistors are used to limit the input current and transistors on the input are added to prevent output transistors from opening both at the same time (that will lead to short circuit) when there is no input,there will be no output neither 1,nor 0.This was inspired from output stages of power amplifiers.
Michael Möller wrote 06/02/2020 at 18:12 point
Shouldn't the symbol for BUFFER in the gallery just be a single buffer (ie just a triangle without the circle at end) and not two NOTs? It doesn't even reflect a double-latency to the single NOT (or is there?)
George wrote 06/03/2020 at 07:39 point
Yes,it should be. ( Falstad does not have that symbol )
Yann Guidon / YGDES wrote 04/09/2020 at 12:46 point
Would you try to implement a ring oscillator ?
George wrote 04/17/2020 at 08:34 point
Maybe once.
Yann Guidon / YGDES wrote 04/09/2020 at 12:44 point
So it's an evolution of #CBJT Logic by @Ted Yapo ? :-)
George wrote 04/17/2020 at 08:35 point
No,it`s independent.
